- Apr 14, 2014
- 3,168
Had a similar self-induced problem with my Delta saw yesterday. After installing the casters, I reinstalled the table. When checking the crosscut it was obvious the blade wasn't at 90* to the fence. I checked all the scales, stops, and adjustments and nothing had changed from the day I got it. I stood there scratching my head for a while before it finally dawned on me there was sufficient clearance in the table to frame mounting holes to cause the problem. I loosened the bolts, tapped on the rear of the table to align it and retightened the bolts. Everything is square once again.
