- Feb 8, 2014
- 11,151
I have been wanting a high speed spindle for my mill for light routing and engraving. I did a project a while back that required that I use my friends router to get the spindle speed that I needed to run the really tiny end mills I was using.
So with a Micro Air Die Grinder from HF, I made it happen. The HF grinder is about 5/8 diameter, so it fit nicely in an end mill holder, after a bit of lathe work on the end.
A little modification to a #30 taper tool holder. I had to drill it 5/8 all the way through, and trim the end a bit. I don't need the drawbar threads on my mill. It got a little warm on the end while drilling, these tool holders are made of some pretty tough stuff. I was only turning at 115 RPM.
The air grinder inserted in the tool holder.
Connecting the air line.
The grinder has a M6 threaded air fitting on the back. This was supposed to provide the grip on the air line in the original configuration. The air line blew off the first time I tried to run the thing, the collar had split so it was loose. So much for Chinese engineering. It worked out well for me, the M6 thread screwed nicely into polypropylene fitting I wanted to use. I didn't even have to make an adapter, it just screws right on. The polypropylene is soft enough that it formed the threads very nicely.
The air line goes down through the drawbar hole. Note: Don't turn the spindle on!! There is an in-line oiler to the right of the regulator.
I need to install a 1/4 turn valve on the regulator as an On/Off switch.
A carbide V-cutter engraving bit installed.
The first test run in a scrap piece of acrylic. Everything worked great!! This is engraved from the back side, so you are looking through the acrylic. To get the contrast in the picture, I'm holding a piece of paper behind it.
~50,000 RPM, 10 IPM, 0.006 deep, with soy based cutting fluid.
This is part of the labeling on my new mill control panel. It will be side lit with LEDs. I'll post that project when I get to it.
