- Jul 28, 2017
- 2,403
Asking for a friend. Recently he did a series of blade life tests vs. blade tension on his saw and got a surprise. Actually two surprises. The first: the blade life was lower than expected, maxing out at around 56 hours of continuous run time. The second: the blade life vs. tension had an inverse relationship -- the higher the tension, the longer the life. The maximum tension used for the test was well below the manufacturer's maximum-recommended tension, and this relationship held true for all 4 tests ranging from 25KPSI at the high end to 15KPSI at the low end. They were all bi-metal blades from the same manufacturer, same shipment so probably from the same manufacturing lot. The blades do not break at the weld, they all appear to originate from the gullet. The life vs. tension curve is close to a straight line with a slope of +2.6 hours/KPSI
The tests were performed with the blade guides removed so the blades were not twisted/straightened during the test. He has a tool to measure blade-tension and a load cell to calibrate the tool, so he had known test conditions. Blade tracking was good during the tests.
Has anybody here encountered a similar problem?
