- Nov 14, 2016
- 3,006
I'm looking at getting a 4x6" bandsaw. It looks like I have several options.
Cost is always a concern, but more important to me is size and power. I do not currently have 220v available, and while I could probably make a larger saw fit into my space, I don't really see the need for a larger saw and I need it portable so am limited to something on wheels in the 100-150lb weight range. This requirement pretty much limits me to the 4x6" class. I know the 4x6" Harbor Freight saw has many supporters.
The Harbor Freight / Central Machinery 4x6" seems to be the standard for comparison, $259, 115v and listed shipping weight is 131 lbs, they don't give actual weight anywhere I can find. Says it has a 6.4 amp, 1 hp motor. 90 day warranty.
Home Depot offers a Wen 4x6" which looks to me to be nearly identical to the Harbor Freight saw, $239, 115v, 109lbs, lists a 4.6 amp 3/4hp motor, same exact speed ratings 80/120/200. Parts breakdown in the manuals is very close to identical, just numbered differently. 2 year warranty.
Home Depot also lists a General International, marked down to $299 (was $417). No longer listed on the GI website so I suspect it has been discontinued. Also looks very similar to the Harbor Freight saw but possibly using castings for some parts in place of stamped metal. About 60 fewer parts listed than the HF saw. 115v, 5 amp 1/2 hp motor, 121lbs 3 speed 80/120/180. 2 year warranty
Grizzly also has a 4x6", again very similar to the others. $339, 115v, 117lbs lists a 5 amp 3/4hp motor, 3 speeds 78 / 108 / 180. 1 year warranty
All saws use the same 64-1/2 x 1/2" blade.
From there it looks like Jet's 5x6" bandsaw would be the next logical step, but at $640 it is more than twice the price of the others, with nearly identical specs to the HF saw except for the motor which is rated 5 amp, 1/2hp. It is upgradable to 220v, don't know what benefit that provides. Also uses a 64-1/2" blade. 2 year warranty.
I don't know how well I trust the motor ratings, I don't understand how a 4.6 amp motor can be rated 3/4 hp while a 5 amp is only rated 1/2 hp.
A major advantage to the saws sold at Home Depot is I have one 10 minutes away and they offer free shipping to the store, the nearest Harbor Freight is 70 miles away.
I've have been watching Craigslist and Ebay. Relatively small saws like this rarely come and they are almost always the HF saw when they do. Most are 7x12 or larger and 220v or unspecified power.
I'd be very interested to hear opinions on the other saws. It isn't hard to find info on the Harbor Freight. I'm particularly interested in the Wen as I suspect it may be the same saw as the HF / Central Machinery so the many DIY upgrades out there would also apply to it.
