- Dec 6, 2012
- 2,682
Like most of the others welders here I try to avoid cast aluminum welding and I always say going in that i can't guarantee it hoping it with scare them off. The clean preheat bevel advise is spot on. I will add this you said low slow heat and my experience is that you need to get it hot and wet try to alloy a good amount of filler with the cast. I also, when I can, run a bead on either side of the crack which alloys the casting and then the money pass is easier and less scary. I also try to figure out why the part failed and what the part will be asked to do.
I would like to see a picture of the piece.
It failed because it got hit when something fell on it.
My limited experience with aluminum cast is that the heat promotes porosity.
I'll get a pic over the weekend, and attempt to provide greater clarity regarding my plan of attack.
Regardless, as always while I'm a decent TIGer I am certainly not an expert, or professional welder. And will gladly accept criticism, correction, or redirection.
Thanks for the input.
Daryl
MN
