4" vise - help choosing the right one
matthewsx
Jan 2, 2019
6,587
So, I'm at the point where my CNC mill/drill project is just about ready to start making actual parts and I think I need to buy a 4" milling vise to replace the hardware store drill press vise I've been using to test. My table is flat cast aluminum and I have some more cast pieces that I think will eventually be drilled and tapped for sacrificial workholding fixtures which I'll use with hex clamps but I know I'll want a decent vise for quick set-ups.
Looking at Shars think I've ruled out the $150 model so I'm down to the $250 "CNC" vise
https://www.shars.com/products/workholding/vise/4-440v-cnc-milling-machine-vise-0-0004-1
or this one for $75
While I'd like to just buy the more expensive one my budget tells me to go with the cheapie. I figure it will be a while still before I'm likely to be splitting tenths with this machine if ever, and "good enough" will be just fine until then. I already have a China built 6" HF vise I've never put on a machine but it seems like it would work if it was just a little smaller. The $250 vise from Shars has a wider jaw opening but I don't see that as a major limitation for my use and probably not worth the extra $175 in itself.
Thoughts?
BTW, here's the machine as it sits now.
Thanks,
John
I've used this one since I got my machine and I have been very happy with it.
Don't go too big. You don't have a ton of Z travel there.
That's exactly the one I decided I didn't want... Is there a reason you prefer it to one of the others, or just what you have?
I'm actually leaning towards the 3" model since I have other plans for larger pieces.
RJ, would love to hear your thoughts. Even if they're snarky;)
John
I have this vise::
on my mill.
I have made hundreds and hundreds of accurate parts with this vise.
However, If I had it all to do over again I would get a Kurt in the 4" to 5" range.
I bought it 5 years ago because it was fairly inexpensive ($105 I think) and could be mounted on its side (which I have done many times) since it doesn't have any flanges sticking out. Pretty sure that's why they call it a CNC vise. Shars sells soft jaws for it ranging from $8-15 per pair depending on the size. It seems very accurate and I have the jaw adjusted for minimum lift.
I don't think it is the best on the market, but it is inexpensive and worked for me.
I have a G0704 BTW and this is absolutely the biggest vise I would put on the table.
I have this vise::
on my mill.
Thanks, that looks pretty much like the Shars vise I'm looking at.
John
Thanks, your table is about as deep as mine so that helps visualize it size wise.
My spindle doesn't tilt and I figure I'll be using sacrificial plates for any fancy set-ups so not sure why I would need to mount a vise on it's side.
Probably going with the 3" version for less overhang on the table.
John
I've done this for doing end machining on thin round parts or anything that is too tall for me to work on if it is sitting on top of 2" of vise. I have 10 inches of Z travel, so a 6" tall part + 2" of vise + 2" of tool gives me no room to work. Flip the vise on its side, lay the part directly on the table and clamp from the side, now I have 2" of clearance.
Just found it helpful for getting me out of tricky setups.
