Call me spoilt, I have three 4-jaws of various sizes (the 10" Pratt-Burnerd with matching to lathe serial number stamped on the back..., a 8" Fuerda and a 5" Bison), swap them to suit the work as the lathe spindle has D1-5 engagements, not a thread.
I find the 4-jaws pretty quick to centre to within a thou" or less with a decent DTI (finger type, not plunger - I don't use two keys either) and use them in preference to the 3-jaw (an 8" Pratt-Burnerd, also matching s/n) even for quick jobs, although it's very good for a 60-year-old chuck, within a couple of thou" still! It may wind up permanently attached to a rotary table?
I also have the rare-as-rocking-horse-droppings native collet set (Holbrook parts are more than scarce and generally don't match up to any others!) and drawtube for up to 7/8" for less-than-tenth accuracy...
Anything really awkward goes on a faceplate firmly clamped, that way if it clears the ways it can be turned
Many seem intimidated by faceplate work, but with some attention to clamping, balance and *keeping the speed down* it's a good way to hold really oddly shaped work that you'd otherwise have to bore on a mill.
Even more run from between-centres machining, but I think it's the only way to reliably turn anything that needs to be taken off the lathe and e.g. checked for a bearing fit or measured. Does shallow tapers nicely too!
I WOULD like a 6-jaw self-centring chuck for thin-walled tubes etc., but I haven't found one in my price range yet... and I need to make a D1-5 spindle nose to go on one of my rotary tables!
Dave H. (the other one)
