- Nov 14, 2016
- 3,010
Actually you really screwed that one up, 6 feet is usually the sweet spot for savings. You need to order 2 more feet.So, I've made a mistake.
I placed an order for some metal. I just wanted some basics in the shop. I got about 60 pounds of remnants in steel/aluminium/brass, and then some specific alloys. Mostly, I ordered reasonable amounts in reasonable sizes.
But, the 4" diameter 1018 round steel... I wanted 12", but then the price to get a second foot was much less than double the cost of the first foot. And then the next foot... well, to my great embarrassment, I wound up ordering a four foot long piece. Woops.
Since you will ultimately have to cut the pieces again in the future to specific lengths to suit different projects, it would make sense to tool up so you can cut it yourself.
This is an entry level saw as an example BUT you will get lots of useful info from members here about the cost/performance tradeoffs of different models.
4" x 6" 3/4 HP Metal-Cutting Bandsaw
<h1>G0622 4" x 6" 3/4 HP Metal-Cutting Bandsaw</h1> <h2>A great mobile bandsaw for small shops and workspaces.</h2><p>The G0622 4" x 6" 3/4 HP Metal-Cutting Bandsaw was designed to cut 4-1/2" round and 4-1/2" x 6 rectangular metal stock. It can cut in either horizontal or vertical positions.</p>...www.grizzly.com
I had to cut some 1" mystery steel rod with a hacksaw, that was the beginning of the end of my thinking a hacksaw was adequate for the shop. Soon after I came up with a project that required cutting a bunch 4" square tubing, that is when the HF 4x6 bandsaw came home with me.
