4 Cylinder Inline Engine
I was able to get some time over the last few days from my (she who must be obeyed) remodeling job to make a big mess and a cavity.
Most of the scarf is in the waste bin already.
Thanks for looking
Ray
Got some more done on the engine starting with the cast iron cylinder liners.
Two of the chunks in the back make 4 liners.
After clamping the liners overnight for the sealing to cure I decked the engine block.
I opened up both sides of the block to get some rod clearance but I didn't have to go that far.
I just like to see the moving parts when possible.
Thanks for looking
Ray
Ray. What's the bore and stroke going to be? About the biggest challenge you have taken on so far. I am watching with interest.
The kitchen remodel project is winding down and I have gotten some time to work in the shop again.
I will try to build a crankshaft with needle bearings on the connecting rod journals. To do this I can't use any type of sealant on the crank assembly like LocTite as it may migrate into the bearings and that would be bad. All pieces will be a press fit only.
Wish me luck.
Thanks for looking
Ray
I fully intended to document the assembly of the crankshaft but in the heat of things I completely forgot.
Clocking the sections was not a problem even when the outer two sections were added and the center rod was removed. These sections do not have a center rod for alignment so I pressed one end section on only about a 1/4" and then took it over to the lathe. The outer section and the next section were then clamped tightly in the 3 jaw chuck and that brought both sections into alignment. Then back to the press to finish the press the rest of the way.
Quite happy with the crank so far.
I cut out two bearing caps on the CNC.
Right off the mill.
And installed on the block.
Thanks for looking
Ray
I muddled over how to line bore the main bearing caps for some time with the equipment and tooling I had and finally decided on this setup.
I know it looks sketchy but it was quite stable and at at 65 rpms it worked fine.
My 3/4" drill bit was just long enough to reach through both ends.
I did have to flip the block around and realign it as my big boring bar was too short to reach.
The results were very satisfactory with a nice smooth turning crankshaft in the end.
Thanks for looking
Ray
