- Mar 12, 2013
- 302
I got a 4" inch rotary table in a bunch of stuff I bought. It turns very stiff and the base where the indexing plate attaches rotates about a half turn in either direction when you turn the handle. Has anyone had one of these apart?
I took the table off yesterday. In order to get the table off you must rotate the above mentioned base as it acts like an eccentric and it rotates the worm gear out of the way so the table can be lifted.
is this eccentric supposed to be pinned? I would like to get the table apart to clean out the old grease but I can't remove the worm gear. any help or suggestion would be greatly appreciated.
