- Jan 5, 2014
- 961
So I will either buy or build this thing but I don't know what it is called.
I have a CAT 1 three-point hitch on my compact tractor. The arms just swing in the breeze so when I back up to an implement it is a pain because the arms just close up unless they are held open. I've used a short 1x2 stick to hold them open but I would like some adjustable spacer thing to do the job. Is that something that I can pick up at tractor supply etc.? If so, I can't find it but then again, I don't know what it is called. If not, I'll build something.
I have the "quick attach" latches on the arms so theoretically I back up to the implement, raise the hitch and I'm attached. Without something to hold the arms just right, it doesn't work.
