I have have a 3 phase compressor with a Square D magnetic contactor. The contactor is wired 4 wire, with 3 phases and ground to the enclosure. The coil in the contactor is 120v. How do I wire that? I can tap off one of the phases for 120v, but there is no neutral. Do I use ground? Do I run another wire from the panel? I don't like the idea of potentially energizing something that shouldn't be energized.
