4
3 jaw questions
3
Like what you see?
10
calstar
H-M Supporter-Premium Member
Sep 26, 2013
406
Likes
102
#1
See the pics for reference. The chuck backing plate has a broken thread at the thread start, I can get it to thread on but it tightens after about 1 1/2 revolutions at which point I stop. Thread is 2 1/4 x 8.I am thinking about using a dremel and removing the jagged broken edge and see how that goes. Any suggestions on how to repair this?
I don't have access to a tap, but that may be what I need to clean it up. Again, the only part of the thread damaged is at the start.
hman
Feb 17, 2013
1,531
Likes
1,045
#3
Assuming you're not cross-threading the chuck, the fact that your chuck tightens up (jams?) at less than 2 turns make me think that you have some foreign material (maybe some of the chunks that broke off the damaged threads?) in the chuck's thread grooves.
I've seen chuck thread cleaners (not sure of the exact nomenclature) that look like a large hairpin made of 1/16" to ⅛" wire, with the ends turned outward and sharpened. You compress the U so the ends of the wire go into opposite sides of the female thread, then release and rotate the hairpin to clean out the thread grooves. Hope this helps. I recall seeing a picture recently, but just can't figger out where.
And yes, it would probably be a very good idea to grind down those nasty burrs.
RJSakowski
H-M Supporter - Premium Member
Feb 1, 2015
2,769
Likes
2,838
#4
A broken thread in cast iron should not be extending above the original surface to cause a binding. I would be more concerned about the nick at 3 o'clock in the second and third photos. A nick will displace metal usually with metal above the original surface. Any defects below the original surface will not cause an interference. That is why we stone out nicks on machined surfaces. They may not be pretty but they don't intefere with use. The surface at the edge of the bore is a registration surface on two sides. Usually th fit is quite close and this would be enough to cause binding.
calstar
Sep 26, 2013
406
Likes
102
#5
"I think I would just chuck it up and bore the broken thread out."
I have a 4 jaw, I can hold a piece of round stock in it, then mount the 3 jaw to the same bar stock, then turn the thread out. Is that what you mean?
thanks, Brian
calstar
Sep 26, 2013
406
Likes
102
#6
I didn't even consider the nick, I'll give it a try tomorrow.
thanks, Brian
RJSakowski
Feb 1, 2015
2,769
Likes
2,838
#7
thanks, Brian
Brian, I would carefully inspect the entire registration surface, both the bore and the face. A nick on the face should affect the ability to thread the back plate on but it will affect the runout. Some Dykem will help to find any high spots.
Chipper5783
Sep 25, 2014
565
Likes
406
#8
Can you track down an 8 tpi tap (1" national coarse, also a lot of industrial bolting in sizes above 1" is 8 tpi)? Then you can scrape through the threads - you use the tap like a "form scraper".
NortonDommi
Active Member
Active Member
Nov 15, 2016
122
Likes
69
#9
I'd remove the damaged portion of thread and a Dremal will be perfect,clean,(scratch brush rotated),and clean out and just see if it screwed on better then sort out other problems. Looking at where the damaged thread is in relation to the start the male may be trying to 'start' twice. Also it does not take much deformation on a tight tolerance thread to cause binding. Do you have or can borrow a thread file? At least you have room to move.
dlane
Sep 27, 2014
2,221
Likes
884
#11
Has the backing plate ever mounted on the spindle correctly? , if not have you checked it with a thread gauge, hardening has 2 1/4 x 10 tpi spindles they look close. Been there with a spindle thread protector, just sayin
calstar
Sep 26, 2013
406
Likes
102
#12
The lathe is 1980s Jet(Taiwanese) 12x36 belt drive, 2 1/4x8 threads; 2 chucks and a face plate I have install easily. I picked up the chuck in question when I just got a 1991 12x24 Chinese lathe, same thread as measured with a thread gauge. The chuck mounted correctly(slightly snug ) on the lathe I was given as does a face plate(easily), which also mounts correctly on my lathe.
I'm thinking the threads may be slightly dimensionally different. If I had a tap that size I'd use it, I think that's the best option but don't have one. I'll get in my shop this evening and try some and try some of the suggested fixes.
thanks, Brian
Silverbullet
Active Member
Active Member
May 4, 2015
2,357
Likes
1,062
#13
You can remove the backing plate from the chuck . It'll be easier to do then spinning all that on your lathe . It's only about 4-6 bolts usually. Plus you can clean the chuck repair and relubed as needed. I wouldn't mount it in the four jaw with the chuck mounted . Just my opinion.
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#14
Also, you can put the Dykem on it then work it on to where it binds. Then look at it closely to see where it is binding., But agree with Dlane as unless it has fit prior it may be a little diff thread, I know the Jet 10x24 I have is a Metric size with a 8 tpi Kinda diff and hard to find.
calstar
Sep 26, 2013
406
Likes
102
#15
I'll remove the backing plate, marking/indexing the plate and chuck for reassembly.
Dykem is a good idea. The thread is definitely 8tpi as measured by a thread gauge, the difference(if the problem is thread size) is most likely a few .001s.
Brian
Kernbigo
Active Member
Apr 8, 2012
629
Likes
154
#16
after you remove the backing plate try to tread it on back wards, more than likely the thread is a little under size in the chuck. You may be able to lap it in with valve lapping compound, i had on years ago that did the same thing.
Silverbullet
Active Member
Active Member
May 4, 2015
2,357
Likes
1,062
#17
I think I have a tap and die in my shop that size , I watch for them on eBay the die I got for $20. If I remember right new not used hss too. I bought them to help make adapters for my logan . I want to make several , er collet 32-40 , Jacobs lathe chuck from an atlas #20 size it's threaded 1 1/2 - 8 . I have it so why not use it.
calstar
Sep 26, 2013
406
Likes
102
#18
Backing plate will not go on farther than a few turns from the back, about the same as from the front. Given this it seems most likely that the chuck is undersize. Any one have a 2 1/4" 8tpi tap they want to rent me? On the other hand it may be best to instal a new backing plate.
thanks, Brian
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#19
Do me a favor and measure the openings etc on that backing plate. It almost sounds like it fits my 10X24 If so I would possibly like to purchase it off you. It sounds like it is the metric size X8 that fits mine. Then you could put a new one on the chuck.
calstar
Sep 26, 2013
406
Likes
102
#20
I googled metric size X8 but didnt turn anything up. Where can I find info on it?
Brian
Tozguy
Feb 15, 2013
1,349
Likes
820
#21
Brian, what did the dykem show?
There are quite a few nicks on the backplate so it might have been mistreated. Or maybe the backplate was not machined well enough to fit the spindle properly.
Either way why not remove the back plate and chuck it in the 4 jaw. Check concentricity and square of the register surfaces and threads. Single point the internal threads a bit to get better clearance and concentricity. The thread fit is not critical. The register surfaces are. To me this a great learning opportunity for you.
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#22
That is one of the problems it is off sized and cannot find anything about it I finaly found some information on some of it by searching the web. But found nothing specific. I made a plug to test with, It is not real acurage but enough for me to check ones I find. The regiser area is about 51or 52 mm or 1.8 something inches. The threads are under that when measured. Some people call it a 2 inch x8 tpi also. I have two Taiwan made 10X24s one is a Jet 10X24 PY that has this spindle.
If you have anything that screws on, Then check things against that, then try the Dykem and see where you are hitting.
Ken
calstar
Sep 26, 2013
406
Likes
102
#24
Yes it is, I've already learned a lot! I do not have any thread wires, might need to get some. The lathe itself is still at the sellers place(10 minutes away, I took only the accessories home), I'm going over there later on to check the spindle size on it and take a face plate that fits my lathe spindle and check with that.
Brian
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#25
Sorry I though you had them both at the home already. YOu are doing smart taking one that fits your other lathe that you know what it is them.
calstar
Sep 26, 2013
406
Likes
102
#26
I went to check out the lathe( cz300), took the back plate I removed from the lathe's chuck and a face plate from my 12x36 Jet(a known 2 1/4 8tpi). The backing plate spun right on, smooth and no resistance. The face plate would only thread on a short distance, then resisted in the same manner the back plate does on my Jet. My thread gauge showed a perfect fit for 8tpi so....sorta strange. I googled cz300 and found a lot of stats but no mention of spindle thread size in any manual or manufacturer spec sheet; I did see someone on a forum state it is 2 1/4 8tpi but that doesn't seem to be the case. If I find anything out I'll post here. I'll also watch some inter web vids on how to use thread wires.
Brian
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,296
Likes
3,495
#27
if i'm not mistaken, i remember seeing somewhere that 58mm x 8 tpi was the spindle dimensions
i have a shenwai 1236, i should pop the chuck off and see if i can verify.
Tozguy
Feb 15, 2013
1,349
Likes
820
#29
So basically we know that the CZ300 spindle does not have the same nose thread as your other lathe. If interchanged parts only go on a turn or two then it seems to me that we have a close enough diameter but with a different pitch, although not by enough to see with a thread gauge. Chances are using wires to measure pitch diameter will not show much if the problem is actually thread pitch.
calstar
Sep 26, 2013
406
Likes
102
#30
Ulma Doctor, that would be great if you can do that.
Tozguy, yep, but thats better to know than thinking a broken thread is the causing the problem(I've learned a lot here). The cz apparently has some gear issues which I knew about before purchase. I bought it for parts, probably to difficult to sell as is, thinking I may part it out. I've not machined a back plate for a chuck so I may give that a try for the cz chuck, or find someone with the same dimension spindle and sell it.
Brian
6
5 7
