3 Jaw Chuck Jaw Alignment Issues
This is the jig I used.....
That puts a good perspective on it. I could get a plate water jetted out that would severve that purpose even on a 4 jaw independent chuck this method would work .you would just have to keep working the jaws around taking readings of the outside of the jaws untill centered and then grind internally. Thanks for that JCP
  • Like
Reactions: jcp
One more question on my mind is what would be a suitable stone to use in my die grinder to grind the jaws .i have two electric die grinders 1 with a 1/8 size chuck and another with 1/4 inch chuck i was thinking of utalizing the larger grinder ?
I would think larger would be better.
