3/8 x 20 tap, correct me if I'm wrong
ddmunroe
May 12, 2014
164
Hi,
What is the background of this tap and where would it mostly finds it uses.
I had to check it 3 times for the pitch and diameter. (It is not marked)
It definately is a 3/8 x 20 tap
Thank's
dd
Don,
I don't blame you for asking ..... it got me too when I measured it .... It's .375 20 TPI
Measured with different power glasses to be sure !
These taps must have a specific purpose.
dd
Are you sure it's not a 9 x 1.25 mm?
9 mm bolts are pretty unusual, in the metric world: generally it's a diameter reserved to handgun bullets :headshot: :biggrin:
3/8" are 9.525 mm: good to tap an 8.80 mm hole for a fine thread M10 ×1.25 bolt… but even those are not very common.
A good table with metric sizes is here.
That's an odd one for me as well, it's listed a UN type thread, UN is designated as "UN bolts and machine screws are the type of fastener in everyday use in the US, UK, and Canada"
Ken
Don,
dd
Found it in a reference book I have "American national form thread special pitches"
Edit: interesting never payed much attention before these "American national form thread special pitches" seem to split the difference between NF and NC, for instance 1/4-24 and 5/16-20 and so on.
Non standard taps are quite common in many trades. I gunsmith and have 7/32X40, 1/2X32 8X40 and 6X48 and use them often. Metric sizes were suppose to make it all easier but I find about as many nonstandard sizes in metric as English The odd ones are harder to find in the metric sizes too. I think I even have a 3/8X20 in my collection. Ever hear of a #7 machine screw size? Well I have the taps and die for that oddball too. 1/4X40, 1/4X50 and an assortment of others. I don't always find the taps and die together. If I find it in a sale it may not be there but if I'm buying it new I get both......just easier to have it on hand than have to order it for that "special" job.
I have a few bolts (and saw a box at a garage sale yesterday) of 3/8-20 and 1/2-20.
I have a little china jacobs chuck that threads onto 3/8-20. I had to make an adapter to fit my homemade lathe project spindle.
