I have a BXA 250-216 Chinese tool holder that is a distant cousin knock off of the A loris bxa 16. It has a positive rake, clamp type triangular coated insert with a center post. I use it mostly for rough turning of rifle barrels (416 stainless). I can take a 75 thou cut on my grizzly g0709 without any strain. (but a lot of smoke ) My question is does anyone know what insert this takes? It appears to be something like TCM?16???. The measurements don't seem to line up with either the metric or inch inserts. The side of the triangle is 15.78 mm. The thickness of the insert is 4.21mm. Looks like about a 7 degree relief on the cutting edge.
Thanks,
Earl
Thanks,
Earl
