Good Day Everyone,
I have a CNC machine which works on 220 v however the place I would like to use it doesn't have 220 V and they are not willing to put it in, that is the problem.
At first I thought, to taking two 120 V plugs on different wall circuits and wire them into the 220 V supply of the CNC. Thank God I researched it, as the two 120 V lines would be out of phase and I don't want to think what might of happened (research pays).
I found out that the CNC machine has an inverter which takes the two 120v line from the power panel and brings them in phase so the CNC can operate safely. I was thinking, what if you took the two 120v line from separate circuits wall plugs and ran them to the inverter, would that operate the CNC safely? Before you jump on me, I will do this only with a lot of research, I don't want to blow up myself and the CNC machine, are there any electrical experts out there that would know the answer?
Thank you for the help,
Vic100
Vic100
