- Dec 8, 2013
- 2,651
Squeals and Judder could be the stage names of a couple of guys doing a radio show about machining.
No one is more suprised than myself, I expected heaps of squeals and judder instead it went through like a hot knife through butter leaving a very smooth finish.
Mind you I dont think it would have had a chance in steel.
Way to use tools available and make your own to solve a job.I needed something to bore two different diameters for a flanged bearing.
Having played with the drive shaft chunk I thought of a use for it.
I turned down the first bit 12mm to fit the existing hole then to fit the bearing dia.
Then an angle grinder to roughly add some teeth.
One end for the bearing the other end for the flange diameters.
Pretty scrappy but it worked remarkably well and produced a clean hole.
Not having a mill I held the tool in the chuck, pressed the face of my tail stock drill chuck against the aluminium side plate to keep it square and allowed the side arm to spin until it hit the cross slide and spin no more
Heres the fit, the screws dont quite touch the flange.
I generally use calipers almost like using a pocket rule, that is just a quick measurement. When I want to be more precise I'll use micrometers, surface gage, etc. I have several cheap Chinese calipers because at one point I was considering using them for a cheap DRO but then figured they weren't worth the hassle.
Now the odd thing is that I have bought other items from Harbor Freight. Invariably the first thing I do with such a purchase is to clean it up, tighten it, remove rough edges, etc. Until I saw the above video it didn't even occur to me to do the same with these calipers.
Anyway, I then went down and deburred them with emery cloth and steel wool. Straightened them, lightly oiled certain parts using a pipe cleaner, and adjusted the little screws so that they were more snug. Then I opened and closed them each 100 times (I counted).
I tested each one on a couple of different gage blocks, taking three measurements each. They now return a much more accurate reading then they did before.
If you have similar calipers I'd recommend doing the same, especially if you're using them as one of your main measuring tools.
Of course that was back in the day, when we were still using vernier calipers.I was taught if you only need a measurement accurate to .001 then a caliper would do if you needed closer than that then measure with a micrometer.
Had to fix a rear axel seal leak on my daily driver (82 Fj40). The recently compleated work bench made it a pleasure to efficiently complete the required work.Turned out a seal installation tool for both the rear and front inner axel seal. View attachment 111031View attachment 111032
