I finally pretty much lost the brakes on my small forklift, so I thought I better take a look. I haven't touched them in the 7 years I've owned her. Turns out they were just out of adjustment but had a pretty good ridge outboard of where the linings touched, and I had a heck of a time loosening the adjusters to get the drums off. Squirting enough PB Blaster in the hole finally allowed me to get them loose.
I needed to get rid of the ridge, and they are about 3/4 inch too big to fit in my lathe. I thought about taking them down to the local auto parts store and having them turned, but then I would have had to argue with the snot-nosed kid behind the counter about how much they could turn and still be ''legal''. OK so they are worn about 0.080, but this machine has probably a total of about 10 miles on her since I've owned her. The major road trip was across the street to the neighbors, to lift a pallet of shingles up to the roof for them. A normal trip is maybe 30 feet at a blazing 1/2 MPH or less.
OK, I have a CNC mill sitting here that can be used as a brake drum lathe. In this case I just programmed in a circle and took 0.010 DOC per pass until I got down to the worn area. I could have used the rotary table but I was too lazy to set it up, besides, I would have had to hand crank it. This allowed me to clean and repack the wheel bearings while I was ''turning'' the drums.
When I got to the right wheel, I found the bearing adjusting nut was loose, backed off about 2 full turns and the lock tab was missing. The mental giant that last worked on it didn't put the lock tab back in and to top it off, cleaned the bearings and
then didn't repack them with grease, completely dry.:*****slap2: I guess I'm lucky I'm not road racing her.
So I made a new lock tab and life is good. And the brakes work just like (almost) new. Maybe I'll have to adjust them again in another 7 years.
