    Dismiss Notice
2 Or 4 Pole For A Rpc
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by quickcut, Jan 4, 2017.
  1. quickcut
    quickcut South Africa H-M Supporter - Premium Content H-M Supporter-Premium
    10
    8
    johannesburg
    City:
    johannesburg
    State:
    Outside US / Canada
    -Return to Top-
    Hi All
    In a RPC does it matter if the phase generating motor ( not sure of a better description) is 4 pole or 2 pole. Secondly may I connect my heat treatment oven to a RPC.
    Thanks
    charles
  2. Wireaddict
    Wireaddict United States Active User Active Member
    37
    28
    City:
    Camden
    State:
    Tennessee
    -Return to Top-
    Personally, I don't see where it maters, you're putting 60 Hz. AC power in, running the idler motor at or near its synchronous speed & getting 60 HZ., 3-phase out, regardless of what the motor's doing. If you have a choice a 4-pole might be better only because it runs slower so bearings would last longer, it'd be quieter & possibly vibrate less.
    quickcut likes this.
  3. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,860
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    the frequency may be at 50HZ in SA.
    but either motor (2p or 4p) would suffice regardless of frequency.
    i would look for a 4 pole motor myself.
    if your oven requires 3 phase to operate, then yes you can hook it up to the rpc
    on the other hand, if your oven operates on single phase, hooking it up to a RPC would be a waste of time and energy
    quickcut and Bob Korves like this.
  4. quickcut
    10
    8
    johannesburg
    City:
    johannesburg
    State:
    Outside US / Canada
    -Return to Top-
    Thanks for the input, Yes the oven is 3 Phase , but according to the electrician could be rewired (external element connections ) for single.
    Ulma Doctor likes this.
  5. Ulma Doctor
    2,860
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    if you are running other 3 phase equipment, the rpc would be a good choice.
    otherwise you may be better off to rewire for single phase operation and save some hassle
  6. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,591
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    If the oven is not new, you may have problems with the elements, wiring, connections, and stand offs crumbling as you try to work on them. In that case I would stick with three phase if that is a good possibility.
  7. tq60
    tq60 United States Active Member Active Member
    200
    43
    City:
    madera
    State:
    California
    -Return to Top-
    A quick look at the oven wiring could be simple enough.
    Likely has 3 heating elements one each across each phase.
    Depending on the voltages one could connect single phase to some connections and have it still operate but at lower output.
    The oven should be built such that the area where the wiring from the heaters to the distribution blocks is servicable so it should not be difficult but the voltage rating of the heaters could make things interesting.
  8. mksj
    mksj Active User H-M Supporter-Premium
    1,359
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    The oven elements are resistive loads, the elements are usually wired to a terminal block and it is the configuration at the terminal block that usually determines if it can be rewired to run off of single phase. The elements are in banks so probably star for 240V 3 phase and parallel for single phase. If the manuals states that this is OK to rewire for single phase, I would go that route, a RPC is not needed. Other considerations are if there is a controller and what voltage it needs, you will also need to change the input wiring gauge to the terminal block and breaker so it is compliant with the increased single phase amperage.
    quickcut and Ulma Doctor like this.
  9. quickcut
    10
    8
    johannesburg
    City:
    johannesburg
    State:
    Outside US / Canada
    -Return to Top-
    The electrician is going to rewire (re-connect) for single phase . He is going to spread the load over two live legs, so that means two separate parallel circuits.
Share This Page
