- Nov 25, 2015
- 8,342
I could not get a gib screw out of my taper attachment that I bought. It was abused. rusted in. This is the follower on the cross slide.
I drilled it out and tried with an extractor, heat.
Ok, so I drill it to size then start tapping. Rather than go all the way. Let's see if I can lay new threads in.. 10-32 about 3/4 of the way, then that uneasy feeling I'm about to break a tap. I try another , not any better. I noticed I had a 2 flute tap, figured it has to be more stout, so I give it a try, it cuts it like butter. No resistance.
So why do we have 2,3,and 4 flutes, if the 2 are so much more stout. I realize that a spiral tap will be even better and cut across an interrupted slot.. but man 2 flutes really cuts well.
So why do we need 3 and 4?
