here is an update of the progress i have made on the headstock.... i forgot to take a pic of the casting after it was stripped and before i painted it! but you can see the before and after in the pics below.
The headstock casting was broken down, cleaned and stripped and then painted.
I purchased new git cups and capillary oilers from Ted so those will be installed when i get the spindle finished.
I also had to make a new brass tube of the oil passage, the original one was pressed down in the hole and i couldnt get it out without destroying it... so i just whipped up a new one.
