- Sep 2, 2013
- 5,122
This one has been sitting outside covered with tarps for a couple of years now, due to a lack of time, space, and things higher on the list. I could really use it now, so I decided it was time to make some space in the old shop and get after it. When I bought it it was powered up, and all the speed ranges worked, but the carriage would only move a few inches. It's a bit of work moving a 5k# machine alone, but I've had quite a bit of practice, so with the help of the backhoe, a floor jack, skates, and cribbing, I was able to get it where I wanted it in about an hours time. I had meant to oil it down when I covered it, but best intentions, and all that. The constant hot/cold cycles had created condensation which eventually left a nice layer of surface rust on most everything. Got busy with rust removal with the parts I could get to, and pulling off the compound, cross-slide, and taper attachment. Decided to clean, strip, and repair each item as they came off so I don't just end up with a big pile of dirty parts. Should make things a little easier for painting and reassembly. Splitting time between the lathe and my table project every few days for a little change of pace. Mike
