- Mar 26, 2018
- 8,434
Hi,
I'm getting acquainted with my new to me mid 70's series 28-300 band saw.
I see there are interlocking collars on the inside and outside the housing. I assume the knob is pushed and pulled to activate the gear reduction.
On mine, there is no movement when I push in or pull out. I can see a brass sleeve inside the outer shaft that would allow for a sliding motion.
Is it just gummed up?
Does it need a tap with a brass hammer?
I don't want to hurt anything. I don't think the gear box has ever been used or if it has, it's been a while.
To change the oil I need to remove the saw from the stand to gain access to the plug?
Thank you,
Jeff
Thank you,
Jeff
