I recently picked up a 13" South Bend turret lathe & I have most of it disassembled & I'm starting to clean everything up.
After cleaning the parts I double checked them for damage & worn-out areas. One item that seems different than others I've seen is the tumbler shaft.
Mine has 4 slots for the tumbler gears instead of the normal two slots.
I could understand it if the original slots were damaged & someone just machined new slots, but both sets of slots look fine.
One set of slots is .125" deep & the other is only about .100" deep. Both gears fit fine on the deeper slots, but only one gear fits good on the shallower slot!
Has anyone seen this done, and what would be the reasoning behind it?
Doug
Doug
