- Dec 2, 2012
- 1,723
I have a LeBlond reagal lathe that has a massive gear in the change gear leading to the quick change gear box. It is imperial threading.
if i want to cut a metric thread does the 127 tooth gear replace the big one in the chain or does it go on the same stud as the big gear and drive the gear box? Or is it the other way round?
I havn't got the gear yet so i cant just fit it and check the feed rate, i'm planning to make it out of a spare disc brake rotor.
Any advise on the translation gear set ups for lathes much appreciated.
Stuart
Stuart
