- Jul 30, 2017
- 477
Follow-up. The Gates BX24 belt works for the 1236T. To confuse things, the PM supplied belt is marked B-25. Don't translate to Gates numbers!
On to more swarf.
I have a PM-1236t on the way... A spare belt sounds like a good idea, I think ill order one - thanks for heads up..!
If you don't mind, what QCTP and size did you go with and what is the distance between the top of the Compound to Center on your machine, Just for fun said his is 3.45 in. or 87.65 mm and he is using BXA from PM...
Thanks Mike...
