- Jun 12, 2014
- 4,818
Three jaw scroll is quicker for a lot of repeat work and for smaller stock, while a 4 jaw independent needs to be dialed in all the time. The 4J independent was really slow for me when removing stock in/out of the chuck a lot. Traditional 4J chucks are pretty wide/rough at the jaw tips, so not very good for holding small stock, say under 1/2". My go too chuck is an 8" combination 4 Jaw, scroll with independent jaws that hold stock down to 0.200". Getting stock in/out of the chuck is quick, and then one can tweak the TIR down in about minute. I use a 6" 3J scroll chuck which holds a TIR of better than 0.001", so it also just as well. I prefer it if I am do a lot of repeat widgets on the lathe. Round stock under 3/4", I almost always use a collet chuck system. Everyone has their preferences, I think getting a good quality chuck in the first place is more important to the user's experience.
I wired my DRO to my machine power on my mill and lathe. The mill has an accessory socket box tied to the main machine power switch, the lathe DRO is hard wired to my power terminal in the control box. Be aware that as to the DRO setting for 120V vs 240V, I Run 4 wire power to the mill and lathe. One switch shuts everything down. Spike current? should be no difference to the DRO if it is the machine power switch or the DRO switch, most electrical equipment have some forum of line filtering and inrush protection anyway.
