To clarify terms, the way I understand it is case hardening is specifically hardening a low carbon steel in the presence of carbon to absorb into the surface of the steel. I'm not sure if these blocks are made that way, but even if they are tool steel and fully quenched, the thicker the piece the softer the core will be.
I've always been tempted, but never brave enough to lay out the coin. I noticed some carbide drills don't list their hardness numbers, just recommended materials like tougher alloys which makes me wonder if carbides themselves vary?
Supplied in molded caseApplicationsIdeal for precision layout and set-up.FeaturesEach block precision ground on all 6 surfaces.Case hardened to HRc 50 - 60.Surface finish from 6 to 16 micro inches.Squareness on all sides to within .0001".(23) Holes: (5) 3/8"-16 tapped; (18) untapped thru...
The cheap import ones are plenty useful as they are. If I already had the right size carbide drills (more than one) I might try drilling them out. Otherwise I would be tempted to buy one good set of US made ones if I had the need to bolt them together.
If you were REALLY on a budget and time was no object, and have a lathe and a toolpost grinder (aka clamped dremel), you could stick the block in a 4-jaw and individually grind out each hole...... Ya know, if you hated yourself.
Just Drill out the holes you need for your current setup.
Over time as you use the blocks for different setups you will come down to just the last 3 holes and well - just knock it out.
Thanks to the Suburban Tool U-Tube video above, I was able to find a used set of three counter-bored 123 blocks on Ebay for $35. No one had bid on them, probably because of the different sized holes in the photos. The description did not even mention this feature. Go figure.
