- Dec 25, 2011
- 10,513
Yes. The Atlas part numbering system identified whatever type or size of machine a part was originally used on. At least up until the palace coup that changed the company name from Atlas back to Clausing, for the most part Atlas did not assign a new part number to an old part simply because the part was used on a different machine than what it started life being designed for. If you look at almost any parts list for any type machine, you will see examples of part numbers that do not match the machine that the part is being used on. So if a part number is 10-242, it is still 10-242 even though the machine it's being used on is a 12". If a table saw had needed a gear like that, the part number would still have been 10-242. Or to put it the other way around, if the part number isn't 10-242, then a 10-242 won't work there.
