- Feb 1, 2015
- 9,621
Had you not been able to identify the terminals, I would have pulled all the jumpers and measured resistance. The start circuit would measure infinite because of the capacitor. Knowing the motor was connected for 110, you would be able to identify the start and end of the run windings relative to each other as the respective ends are tied together. To set up for 220 then, the start of one run winding would be connected to the end of the other and one of the start circuit terminals would be connected to the junction . 220 would be connected to the other ends of the run windings. The remaining start terminal woould be connected to one of those terminals. You still may have to switch that last connection to get the right rotation but the motor would be safe to power up.
