Thank you Nogoingback! I appreciate the many posts you've made on the site that I've seen in the past.Why do you want to remove it if it won't be replaced? If you want to re-pack it, you could probably do it in place.
I'm interested in doing just that. I'm assuming I need to remove the seal to do so and was hoping the other side might be shielded, but it doesn't appear to be.
I was assuming I needed to pull the bearing in order to properly flush and re-pack. Have you seen any good step-by-step write up on this with a sealed bearing?
Absolutely should be seals on both sides. Logan used high quality permanently lubed bearings.There is no seal on the outer side of the bearing? If so I think somebody installed the bearings wrong. If you can see the bearings on the other side it means they were open to swarf and probably shot anyway.
