- Jan 2, 2019
- 6,543
Probably go with ceramic belts and cut both mild and HSS. May want to do carbide, looking at silicon carbide or maybe CBN but might save that for my tool cutter/grinder.nice buy.
so having a belt, I would think mild steel gets cut on the belt.
I'm assuming HSS on the wheel?
Or do you want to cut carbide?
Assuming HSS, a Radiac white, or pink.
What size wheel does this surface grinder take?
It is a covel. I believe 6x18. Would this be a 6 or 7” wheel? What about the thickness? That is with the nut flush. Also I’m sure there’s not a one type fits all but if you were to recommend a single wheel what would it be? I’m trying to sell this surface grinder but toying with the thought...www.hobby-machinist.com
