- Jun 12, 2014
- 4,830
The 1340GT is a light weight lathe and already a bit top heavy with a narrow stance, so it is much more sensitive to imbalance. I had a Chinese 8" chuck that I couldn't get past 400 RPM, so unless you have a higher quality chuck and everything is dialed in, I would not recommend a 10". The issue with an 8" 4J independent (and also 10" 3J scroll) is there is a recommended stock holding range, and it is around 7.5 to 7.9" with the jaws reversed. Two piece jaws seem to give a bit wider clamping diameter when reversed, so you would want to check the model. A 10" 4J independent with 2 piece jaws as well as solid jaws will hold a 8" disc. If you are clamping an 8" diameter and the jaws stick out more than an 2" beyond the diameter that gives you a 12" swing, my understanding is that you want at least 5 jaw teeth engaged for safety. I probably would keep the RPM under 400.
This is a relatively inexpensive 10" plain back 4J that may be worth looking at and asking it's hold diameter.
10” 4 Jaw Independent Manual Chuck Plain Back TMX Brand 3-850-1000 | eBay
TMX 10” 4 Jaw Independent Manual Chuck Plain Back 3-850-1000. - Notes: Manufactured to TMX specifications. - Jaw Type: 1 Piece Solid Reversible. - Spindle Mount: Plain Back. - Type: Manual Chuck. - Recess on Back of Chuck: 4.33”.
www.ebay.com
