- Jul 17, 2020
- 323
I just sheared some of the teeth off the timing belt that's on my 7x14 mini lathe. The one at LMS here is out of stock, estimated to be back in May 9th. Does anyone have any idea where else to find these belts and get them in a reasonable amount of time (not China)?
From some measurements I just took, the 1.5x70 printed on it means module 1.5 (like gear module) and 70 teeth. Using calipers on the teeth measures about 4.71mm, which is module 1.5. The belt is 330mm long.
Some day I'll ditch the belt system that's on it in favor of something more robust. That day however is not today.
