- Dec 12, 2016
- 497
Google "exhaust header flange 1.5", here is the first hit:
This is the route I would take. For under $6/pair, that buys you a lot of effort with a file. If each piece takes you an hour to make, would you like to spend 4+ hours with a file, or spend $12 for pre-fabs? My time, especially with a file, is worth more than $3/hr. I don't make my own standard grade nuts or bolts for the same reason, my time is worth more than it costs to buy small hardware that may even be better than I can make in my shop. So just because you can, doesn't mean you should in this case. That's my two cents, which means you're less than $2.98 from buying a flange off the shelf.
