I started with the Astro Pneumatic set, then added singles as needed from McMaster
Same. The Astro Pneumatic set has worked out for me. Used them to hog out cast iron "flash" to make room for my stepper motor for my ELS. Made an unbearable job into a finite one.I started with the Astro Pneumatic set, then added singles as needed from McMaster
PFERD 5-Piece Tough Bur Set - 1/4" Shank, Double Cut 3R Tungsten Carbide Burs for Efficient Material Removal and Precision Work - Part 26551 https://www.amazon.com/dp/B0742MV7N...ann_lstpd_KEF0GP5R0BM2GWHM5T85&language=en_USI tried some of the cheap ones and then ended up with some Pferd carbide ones. They actually sell them on Amazon and MSC but only as singles, no set. But there are not that many different forms you need. I mostly use cone, flame or cylindrical.
Okay, they sell a set. that may be worthwhile if you need exactly those burrs. they get expensive in that size. I mostly use 1/8" in my milwaukee / dremel style tool.
