- Jan 4, 2016
- 11
I'm needing to mill, drill and/or bore a 1.25" thru hole in .75" 1018 CRS on a 17 degree angle from vertical. Would the preferable method be to mill a flat then use a twist drill or could this be made with a boring bar which would start and end with an interrupted cut? Twist drills and EM options seem to be more limited and $$$ at this size. Please kindly advise how you would go about this using a manual mill to produce this feature.
