- Dec 25, 2011
- Location
- Spring Branch (Houston)
Subtract the pitch from the major diameter to give you your minor diameter. Example 1/4-20. Pitch is 1/20 = .050" so .250 minus your pitch (.050"). Minor diameter is .200". The important thing is to be able to hit the right pitch diameter for the clas of thread. The Pitch diameter is an imaginary diameter where the v of the threads have the same distance across the thread and the v where it is bisected. Think of a triangle. Two imaginary lines form the cylinder and this is your pitch diameter.
Sorry, but this isn't quite correct. It is difficult to give the MOLO page numbers that apply because there were 10 versions printed over the decades and pagination varied. And due to potential copyright violations, we haven't allowed the scans of several of the versions that are floating around the Internet to be uploaded to Downloads. However, I stretched a point and put Chapter 7 - Threading from Versions 1 and 9 in Downloads. If you look on (printed, not file) page 104 of Version 1, near the top of the page it says that the minor diameter is the major diameter minus the double depth of thread. The single depth of thread for the almost never made exact (sharp at both major and minor diameters) 60 degree V-thread is 0.866 (Cosine of half of the 60 degree included angle) times the pitch. On page 135 is Table V, Depth and Double Depth of National Form Threads. The line for 20 TPI shows that the number to subtract from the major diameter to get the minor diameter is .0650" or .0758", depending upon which cutter shape you are using.
