- Sep 24, 2020
- 1,923
Start with 3/4 stock.Measured it at .622 to .624 so it's going to be tight. Maybe a big file?
I have a part-off jig I use to cut within a couple thou. Then will cut to exact size and debur with a spindle stop. 12' long stock supported in chuck and V block about 1' out so it doesn't whip.Use your ER chuck. Cut the pieces 4" plus the width of your parting blade. Turn half, flip it, turn the other half, then part. An ER collet will have the range to hold .618" to 625". Nothing you can do if it won't clean up but it'll be close.
