Old Logan Lathes
Thanks for the help. I have the number on the bed but unfortunately it doesn't have the plate MW plate with it. Is there any other way to find out the serial #
The number on the bed is the serial number.
I looked at the chart and couldn't finure it out. I talked to a guy with logan and all the info I got was 1941 MW
OK guys, as we all know, no pics, never happened. ;) Mike
If you talked or conversed with Scott Logan in writing, and all he told you is that it was a Montgomery Ward machine manufactured in 1941, it is likely that it is the only information he has on it.
Logan would not know who the original owner of a Montgomery Ward machine was. Since it was 1941, Monkey Wards only listed two metal lathes in the catalog. The "deluxe" model has roller bearings in the headstock and power cross feed.
Check out page 18: http://www.vintagemachinery.org/pubs/657/847.pdf
So if it's roller bearing with power cross feed I believe it is a W 700 if it's plain bearing W701
Hey thanks alot for that link. I have the deluxe & I also pick up a old table saw sitting on the side of the my buddies rent house a few years ago and couldn't figure out for the life of me who made it until now!
