- Jan 6, 2017
- 1,220
I got the wire harness from Amazon yesterday. The quality appears surprisingly good, and the wires are definitely all PTFE.
They are all black, but labeled. I went through the 14 pin connecter with my multimeter and it seems to be pinned correctly for my HartK PCB.
The only issue I found was that the 5v supply wire is labeled CT. I have no idea what CT means. Previously I had 5v tapped from the RGB led output. This time I may change a jumper setting and use a fan header, just so I don't have to depin any of the connectors.
