- Sep 28, 2013
- 4,330
Mic6 alu plate will get you a long way to the tolerances you're after and I think it might be a little harder (not to machine though) than regular 6061. Not 100% sure on that last part, but I know that mic 6 is used for fixture and tooling plates where higher tolerances are required, but not so high that surface or Blanchard grinding is called for.
Good looking products and good luck with your enterprise!
