- Feb 1, 2018
- 1,868
Very nice job, I really like the way you bent your brass tubing. Can you tell the members how you got them so nice and not crimping them? I would use the armor coated hoses though as a hot chip or continuous rubbing nylon tubing will cut a hole in them. When I used to install lube systems I would plump in a cheap pressure gage and mark where the needle went to when new and made a little sign that said . " lower or no pressure means a leak" & If the pressure goes up, something is plugged". A question too, are the ways milled or ground as they don't look like there are any scraped oil pockets? Are there any oil grooves in the long ways to distribute the oil down the ways or just those little short ones by the holes?. I used to grind or cut long long diagonal ones in ways to make the original design better.
