- Jun 12, 2014
- 4,847
Not many keyless chuck that would go that big, and not recommended to use one for that size. The runout when you get to that size as well as the forces and holding power is a problem at 3/4". I have two of the Llambrich's chucks with integral shanks and have been very happy with them, but the largest size is 5/8". On the rare occasion that I need to hold a drill or tap larger than that size, I use an inexpensive Z-Live 3/4" keyed drill chuck, there is probably little value in getting a better chuck that large, although I wouldn't mind having an older Jacobs 18N in good condition. The older Jacobs chucks may be rebuildable, but parts are not readily available and expensive. On the lathe, any drilling above 1/2" I use MT2/MT3 drills, and on the mill I have a set of S&D drills to 1" with reduced shanks. I almost never use them, and when I did in a keyless chuck they broke the chuck. Better to use annular hole cutters then larger drills in a mill with a chuck.
On the one keyless Llambrich's chuck, it holds regular drills without slipping with hand tightening, but for tapping and occasional end mill use I always tighten it with the key to increase the holding power.
This may be worth considering LLAMBRICH L40120B:
Keyless 3/16"- 3/4" Drill Chuck Self Tighten With MT3 (Morse Taper 3) Shank | eBay
Suitable for drill presses or lathes spindle accepts MT3 (3MT) shank. MT3 (morse taper #3) arbor included. Self-tightening key-less feature automatically increasing gripping force, high reliability, and stability.
www.ebay.com
LLAMBRICH L40120B - Performance Ball Bearing Drill Chuck with Key 13/64-3/4 J3 | eBay
Find many great new & used options and get the best deals for LLAMBRICH L40120B - Performance Ball Bearing Drill Chuck with Key 13/64-3/4 J3 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
