- Dec 25, 2011
- 10,538
One more thing that you should do is to remove both bearing caps one at a time and measure the remaining thickness of the shims that should be found under each end of the bearing caps. These shims are originally 0.010" thick and are made up of five pieces of 0.002" thick shim stock.
If you didn't acquire a copy of the Atlas Manual Of Lathe Operations with your lathe, you should acquire one. This manual was first printed in 1937 and was revised several times between 1937 and 1982. From 1937 through 1953, all say Copyright 1937. Plus in most years there was a version for the Atlas 10" and one for the Craftsman 12".
Back several years ago I wrote a history of the MOLO and in gathering info for the history bought a bunch of the MOLO's. Unfortunately, I ended up with more for the 10" than for the 12". However, I think that I have one extra that would match you machine. I have about $33 in it and you may have one of them for that plus MM postage. Assuming that you don't already have a suitable one of course.
The reason that I kinda got sidetracked on the MOLO is that in the correct version, it explains all about the care and feeding of the babbit spindle bearings. After 1953, there is nothing in the MOLO about the babbit bearings.
