I've done electroplating before using homemade or purchased solutions but decided to try it again.
This rusty bolt and wing nut seemed like a good test piece. It was rusted bad enough that I used some heat and a vise/pliers to get the wing nut broke free.
This is after a little work with a wire wheel to clean the loose rust off. Wasn't as bad as it looked and it could be reused as is for some things.
After a few cycles of plating and cleaning I ended up with this dull coating.
After a little light wire wheel work, I got a fairly nice shiny part. Still very pitted and the threads aren't perfect but the nut screws on easily by hand and hopefully it will resist rust for a while.
I didn't measure anything making my plating solution but it is a mixture of citric acid, water, and a little bit of table sugar. The zinc was a long piece of zinc I cast using a piece of angle iron as the mold.
With no power hooked to it, the anode is bubbling and slowly dissolving into the solution so I'm hoping this solution will work better when more zinc is dissolved in it but it seemed to work so far even though this was only made a hour or two before using it.
I broke my power supply that I used before to electroplate so this time I used a cheap 5 volt/3 amp power supply.
I plan to use this solution or the same homemade mixture to set up a better plating tank/tub/bucket with a better method of cleaning and degreasing the parts but this quick test proved to me that a homemade solution and a cheap power supply gives usable results. I haven't tested this plating to see how good it holds up exposed to the weather and road salt but it should be better than nothing.
