- Feb 14, 2020
- 166
I have some higher-end mitutoyo digital dial indicators I picked up at an auction. I love them. But it irritates me to hell that there’s no delay between triggering a zero using the origin button and the unit actually establishing the origin. Without fail, the pressure it takes to push the button causes the unit to read +\- and not actually 0.0000. The pressure required to turn the fine adjust on my magnetic holder also results in it being nearly impossible to establish a true 0.0000 origin. If I’m mounted to the mill, no problem, use the mill’s X, Y, Z to get me to a zero origin. But sometimes the base is mounted to a surface that has no fine adjustment.
Is there a mag base/arm out there that has the holding power and fine adjustment capabilities to help me out here? I’m using some bargain bases from Amazon made by Clockwise.
