So, I have been working on a X-Y ballscrew conversion for my knee mill. After spending the last several months designing and machining parts I finally assembled everything earlier this week, only to find way more backlash than I would like (around 4-5 thousands on the X axis). Walked back into the house, my head down, dejected and tired. I guess I was just expecting it to be perfect the first time round (silly me
So after sleeping on it, I came up with a plan. Today I increased the preload on the Y axis ballnuts, and added a shim between the bearings in the bearing block to decrease radial play. Backlash on Y is now down to just under 0.001", which I can live with , but I'm not sure if I'm happy with. So, what's the deal, what do you guys consider a "reasonable" amount of backlash in a CNC machine? For what it's worth, I think the remainder is from spring in the machine components, not sure how much better I can do.
I still have to rip the table off to get at the X axis assembly, but things are improving. At the very least I shouldn't have any more issues with climb milling, and my rapids are up to 120inches per minute (haven't really tweaked them any more to see if I can go higher).
