- Sep 25, 2014
- 1,152
New CNC guy here - having lots of fun with it. I went the route of getting a 20 year old industrial machine and, so far, it has been a positive experience. It is a Bridgeport VMC 1000/22 - it really just needed cleaning, power , fixed a few small computer glitches and away it went. To date I have been entering my part programs through the MDI (manual data input) - one line at a time, proving each step is doing what I want/expect. Obviously my part programs are pretty short and pretty simple.
Is there sort of a typical approach to setting up the Z-axis parameters? I'm not thinking of the specific steps for this particular machine or its' G-code dialect (it is DX-32).
Right now I describe a Z-position that puts the tool well up out of the way, then step through the program in block mode - which gives me the chance to measure the Z gap. Then I edit the code to bring the tool to where I want it. When I do a tool change, I go through about the same steps (keeping track on a note pad for the desired Z positions).
That works, but obviously it is not what was intended. I assume that when setting up a program there is some sequence of defining the the part Z-axis zero, a Z-axis clearance point, tool length offsets, and . . . . ? The menu selections for doing all those things are pretty straight forward - just wondering what approach to take on defining all those terms.
All my stopping, measuring, "air cutting", editing etc. is goofy.
Regards, David
Regards, David
